This has happened 3 times and it's worrisome each time. I will be stopped or very close to being stopped and my brakes will not work. I mean they go to the floor and the truck keeps going even if it's only idling. The first two times I was really worried about how I was going to get back home to work on it without brakes, but when it happened yesterday I had thought about it and I took it out of gear and revved it up a little and it went away. It seems to have something to do with the vacuum or maybe it's because of the low speed, but it goes away when it's revved up. I've checked the vacuum lines going to the brake booster and they seemed fine, but I have a vacuum gauge tester someplace around here, if I can find it.
Do you think it's something to do with vacuum or a vacuum leak or something? It goes all the way to the floor and the brakes do NOTHING, but goes away.
Another similar thing is that I don't have a emergency brake, it goes to the floor and has no effect. I have heard something to the effect that the 'automatic' rear brake adjusters don't work well on the earlier trucks and don't adjust.
Do you get what you pay for in brake linings? I've seen linings from less than $20 up to $100.I mostly (always) use my truck for really light work, I have construction tools I carry and sometimes some plywood or sheet rock so I don't really need the fade resistance that some people need when hauling heavy and down hills, etc. Is there anything to the carbon linings or the expensive things like Kevlar? I assume that they need metal or some type of metal powder that's mixed up in the lining, but I think most cars have that too.
I was planning on putting the one ton cylinders in the back drum brakes-I heard about that here I think.
Edit: This is for a 1994 reg. cab automatic, 2WD 100% stock. I wrecked the 2005 in my signature-but is there brake parts (like brake booster or calipers) that I can take off the 2005 for the 1994, or is everything (brake-wise) entirely different?
