OK.....I have an A pillar with 3 gauges and a 4th Fuel Pressure on steering column. A few weeks back my gauges stopped working unless I had my Lights Turned on...which I always have. So I installed a new Headlight Switch ...from Oreillys.
Not only did it not solve the problem....it made it worse....with the new switch....NONE of the 4 additional gauges worked! So i put the old one back in....worked as before....meaning everything ONLY worked when the headlights were on!
Also intermitently the Fuel Pressure Gauge and the EGT were giving way false readings.....like at idle the EGT's were 1200....the FP....20+. Normally the FP is 15 and the EGT's at idle (with no hard work) will be at 400 ish.
NOW today...MY Oil Pressure gauge--on the factory top right gauge....goes from 50 to 0....and then back again...No reason....not affected by headlight switch...however I did restart and temporarily It also rings a bell and the dash says Check Gauges....OK....HELP.....what to FIX?????
