Towing 6000 Lbs. (GCVW +- 14000) over steep I 15 hills through Montana. 1999 2500, 275 injectors, edge three stage box, Raptor pump on the frame, 4 inch exhaust, waste gate orifice, 3. 55 gears, 47Re trans. , ATS triple clutch TC, ATS lockup controller, Edge box in the #2 position, fuel pressure at WOT 10-13 PSI. In overdrive, climbing steep hills above 4000 altitude. Moderate to violent bucking occurred. Turn off OD and issue disappears. transmission temp 130-150. transmission built by top tech about 9 years ago.
Any opinions would be appreciated. Of note, on our return trip, the symptoms disappeared, and the same hills were climbed in OD, and the fuel pressure came up to no lower than 14 PSI.
Many thanks!
Ron
Many thanks!
Ron
