BK
I have a 99 2nd Gen (from new), with my 3rd LP replaced about 2 years ago. Way back when, when replacing the 1st, I used the Geno's relocation bracket and put the new one I sourced from Cummins back by the tank. At the time I worked for a company and we had an account with Cummins, and I was able to get 3 pumps super discounted on the campaign they had way back when for an industrial application.
I presently have an ISSO FP gauge.
Just a month ago, on occasion the FP gauge starting showing erratic reduction in pressure at idle, say when sitting at a red light, but was perfectly fine when cruising on the highway or around town.
The FP gauge's needle would jump down and up and down, making it's way down to 5psi erratically.
Take off, slow and easy, or hard, makes no difference and it would nicely work it's way back up to 14-15psi fairly linearly, and stay there till the next red light.
The tank is filled with diesel (so thinking it's not a pickup issue??).
The truck runs just fine, nothing strange. Idles well, and nothing sounds strange when the fuel pressure changes.
Finally happened when I was pulling into my driveway, and left it running, ran out checked the sender, gave it a wack, ran back into the truck and the pressure jumped up to 15psi from 5psi.
So thinking GREAT!
Did it another time.. ok great.
It's the original snubber hose from 20 years ago. Outer jacket was all cracked up, so really needed to go.
So figured, new sender and snubber hose.
Just finished installing both, fixed the leaks in the new plumbing after a few test drives, all leaks gone, and sitting in the driveway, it started doing it again.
MF! Mood took a hit.
In parallel of the Geno's ordered, I ordered a mechanical gauge and hose, so I could co-witness the pressure (if it happened again). So installed the mechanical gauge in a port in the tee I installed with the new hose, and damn, the pressure is doing funny things again at idle-both gauges agree. The ISSO and it's sender were telling the truth.
The hose had to go anyway, but the ISSO sender was only a couple of years old and 95bux, oh well.
The issue is intermittent when it started, seems more persistent now maybe.??
When I was test driving, and it wasn't doing it's thing, with the new sender, it was at 14-15PSI at a stop and at WOT go down to 11-12. LP seemed strong. Than WACK, thought I was done for the day, and it started it's dance down to 5PSI when just sitting there in the driveway at idle.
So when I installed the last LP few years back, I bought a stock replacement FASS and associated parts from Genos, so plan installing it tomorrow (Sunday).
Any thoughts???
If it's the LP , I could see it being erratic at idle and at cruise. Not this strangeness of seemingly fine at cruise, but comes and goes with the erratic behavior at idle down to 5psi.
Can't handle the head pressure at idle? Cruise reduces head pressure so the failing pump is better?
(Fuel filter was just changed in the fall)
I'm hoping for a good reason to sleep well tonight before doing the new LP in the cold tomorrow.
TIA,
Bob
So thinking GREAT!
Any thoughts???
TIA,
Bob
