off set ball joints
Killer Dowel Pin
Wheel hop when turning corners
Who is selling them? TIA
2001 RAM H. O. 6Sp 2500 SLT 4x4 Quad Cab, 4Wheel Disc, 4. 10 Limited Slip, Fog Lights, Muffler removed, Silence Ring Gone, Autometer Pro Comp 60# Boost & Pyro, Banks High Ram (Red), Cummins Red Valve Cover, K&N RE-0880, Skyjacker 2. 5 lift Class 2, 7218 Dual steering stabilizers, Custom Pro Fab Trackbar (sweet), EGR Flares (nice fit), Centerline Comet III 16x9. 5 with 305/70R16, Smittybuilt stainless nurf bars, ExTang BlackMax tonno, THIS IS NOT A HOBBY, THIS IS AN ADDICTION !!! MAINLINING DIESEL !!!
I just picked up my truck at Bear Frame & Axle 303-781-5575. So far no pull and I have tight stearing! You can call them and ask for Steve Drake and he will tell you who makes them.
He showed me one and they look well built and it is adjustable. Per invoice it looks like the cost is about $85.
I will give you guys a better evaluation after the weekend. #ad
Frank
01 White, Quad Cab,Short Box ,Sport SLT+,5 speed 3. 54 Ltd-slip,4X4,line-x ,Nerf bars,fiberglass tonneau cover
I hope this cures the pull and loose stearing (they just mfg the new off set joints for our trucks). The truck is in the alignment shop this morning and they are installing the new off set ball joints. I will post later on to tell you if it works!
Frank
The results are in and... ... . No more wander, tight stearing.
Frank
Great. Let us know where the Ball joints came from. I've looked everywhere and no one in the parts business has been able to find any. Also, did they come with grease fittings?
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, SPA EGT/Boost Gauges, Fog Lights, Real Backup Lights, Molded Running Boards
Yes they have grease fitting. See the 1st post and Bear Frame and axle will tell you who makes them (I was the first one they did for the 01 changes).
Frank
