Gauge Fogging
3/4" pipe plug astern of oil filter?
96 Green dodge cummins vs 80's white T-bird
Is there anyone that has AutoMeter Pro Comp Ultra Lite Pyrometer gauge that fogs? It fogs up just about 1/2", on edge.
2001 RAM H. O. 6Sp 2500 SLT 4x4 QC, 4WDisc, 4. 10 LS, Fog Lights, Silence Ring Gone, Autometer Pro Comp 60# Boost & Pyro, Banks High Ram (Red), Cummins Red V. C. , K&N RE-0880, Skyjacker 2. 5 lift Class 2, 7218 Dual steering stabilizers, DT Pro Fab Trackbar(sweet), EGR Flares (nice fit), Centerline Comet III 16x9. 5 with Goodyear MT/R 315/75R16, Smittybuilt SS nurf bars, ExTang BlackMax tonno, Jardine Exhaust W/5" SS tip, " DON'T LET FEAR STOP YOU"
I just bought and installedan AUTO METER EGT gauge in my truck and the first morning I got in my truck to go to work I found the outer edge of my gauge was fogged. I just called GENO's GARAGE, where I bought it and they are sending me out a new gauge, because they are sealed gauges. So If I were you I would check with whoever you bought it from. Good luck
2001, 2500, automatic
30 ft 5th wheel trailer
Jim B. Pgh. , Pa.
The fogging IS NOT isolated to just AutoMeter gauges. I believe under the right circumstances you will find this will happen with just about any of the analog gauges. All of the gauge fogging problems I have heard about have been when they were mounted on the A-pillar. I experienced this when I first installed my VDO Vision series gauges on the A-pillar. I later used a special tape to cover the hole in the A-pillar panel used to route the wiring. This minimized the problem however, it did not eliminate it entirely.
My Sport Comp EGT gauge fogged for the first week i had it. It has been fine ever since. If it continues to fog even after a month or so, you may need to vent the case since it is sealed unlike the other gauges.
