Okay here is the numbers I got from cummins for trouble shooting lift pump pressures. I seen the #s on the paper that cummins uses.
10 PSI min. at 3200 rpm no load
2 PSI min. @ full load
10 psi max return line restriction
6 inhg max fuel inlet restriction
5 PSI drop across the filter
