Steve St.Laurent
Staff Alumni
I agree with what dresslered said. I got a bad load of fuel from a station (you can read the details here - https://www.turbodieselregister.com/forums/showthread.php?s=&threadid=12655 ) and within 2 miles of leaving the station had a 2 psi restriction across the filter whereas I had none before the fillup and had a bad hesitation. I changed the fuel filter and had no restriction initially, but within 2 miles I again had a 2 psi restriction across the filter! If I hadn't have had my fuel pressure gauge on the truck and been able to compare pre and post filter pressures I would suspected a bad lift pump instead of knowing it was a bad fuel load. Being able to read pre and post filter pressures saved me a ton of debugging time and expense!
