Here are the results from my latest oil analysis. The oil is Amsoil 5W-30 heavy duty diesel oil. The full flow filter is the LF-3894 Stratapore. I have the Amsoil bypass filter system installed(it has been on the truck as long as the Amsoil has been in it). I have had samples analyzed at 7,500 mi, 15,000 mi, and now 22,500 mi. The results follow:
All values are in ppm by weight unless specified.
7500 15000 22500
Aluminum 1 2 3
Chromium 0 1 2
Copper 3 8 14
Iron 3 28 41
Lead 1 5 6
Nickel 1 0 0
Silver 0 0 0
Tin 11 1 2
Molybdenum 0 0 1
Silicon 4 8 10
Antifreeze 0 0 0
Water % 0 0 0
Soot (% trans) 0 0 0
Oxidation (% allow) 0 0 0
Nitration (%allow) 0 0 0
Sulfur (% allow) 0 0 0
Viscosity (SUS) 250 285 300
Incidentally, I am running the K&N RE-0880 air filter. I always take my samples from the center-well of the full flow filter immediately upon removal. This seems like the most valid sample point to me due to the fact that this oil is the oil going to your bearings. I believe some are taking their sample from the clean side of the bypass filter. This is not a representative sample and will lead you to believe things are better than they actually are.
99,2500,ISB,QC,6sp,3. 54,4x4, turbo silencer ring removed, Scotty System, B&W Turnover Ball Gooseneck Hitch, Amsoil Bypass Oil Filter System/Amsoil 3000 Oil. ISSPRO Boost and Pyro Guages, Apprentice member of BOMB.
7500 15000 22500
Aluminum 1 2 3
Chromium 0 1 2
Copper 3 8 14
Iron 3 28 41
Lead 1 5 6
Nickel 1 0 0
Silver 0 0 0
Tin 11 1 2
Molybdenum 0 0 1
Silicon 4 8 10
Antifreeze 0 0 0
Water % 0 0 0
