Looks to me like the results were good with Delo.
I notice a plummeting boron and molybdenum reading.
Are you on the new CJ oil?
I would say at the least, you should probably halve your OCI. With the solids that high, you would be a good candidate for a bypass filter. I have yet to see greater than 0. 3% insoluables, and although mine isn't BOMB'd, it was still smoking hard because of a screwed up timing issue.
JHardwick: also notice that the Delo was only around 2500 miles... less than half of what he ran with Amsoil.
steved
If I were to cut the OCI in half I would probably go back to Delo.
Read this (not to scare you, just something to consider):
New oils and related failures. - BOMBER Board
steved
steved
2x the miles and over 30x the soot
The only thing to do is remove a varible and try it again. Either run a OCI with no Smarty, or with Delo ,,,,,,,,,,,,,, don't do both.
I was kinda hoping for someone to post their results.
Results? You mean UOA with and without Smarty?
steved
Yeah, anything. I'm just curious how it compares to other trucks.
I know I am not the only one pushing some fuel with the Smarty and driving short distances. I may be one of the few who sent a sample though.
The copper is nothing to worry about... I have seen a lot of UOAs with Amsoil that come back with smoking copper for whatever reason. IIRC, they indicate it is a result of the oil leaching copper from the oil cooler.
The iron is elevated, probably a rsult of the oil being abrasive due to the high soot content. A bypass may cut down on your soot loading, thereby keeping the oil less abrasive.
steved
Also, if you notice, his oil increased in viscosity... mine did the same thing on the last UOA... I believe it is probably likely that the oil "cooked down" as I have very little soot/insoluables.
steved
