Oil Brand to use ...confused!
Exhaust
Anyone Have Geno's Seat Covers?
I just read a post in the 2d gen forum. That blasted castrol and quarker state oil. why such a hit on these 2? I use syntac in my truck why is this wrong.
please leave a commnet as to why these are bad and what I should use and why.
Curt:confused: :confused: :confused:
At one point I used Castrol synthetic in my cars and chevy 6. 2 diesel and was happy with it. When I bought the cummins I called castrol and asked if it could be used in the cummins and they recommended against it, so I stopped using it. I am not sure why, they just said would was not rated for use in that engine.
oil choices
There are TDR guys who work in the oil business and they can correct this if Im wrong... . The Castrol Synth is just fine for its intended use... . I've got no beef with it. Q-State's oils are parafin-based and will gum up an engine quickly. Years ago I owned a V-6 Mazda. The old-timer tech at my local dealership advised that just topping up with 1/2 Qt of Quakerstate would gum up my lifters in a matter of a couple hundred miles and pound the valve train to death! Not good in the turbo cooler lines... . Play it safe: Delo, Rotella, Amsoil, etc... dont take chances with an expensive motor to save a few bucks. Just MHO, but sound advise, I think.
Adam,
Get the Fleetguard from Geno's or your local Cummins. The OEM filter probably will be fine too... it looks suspiciously like a Fleetguard to me.
Don't skrimp on the filter!
Adam...
I use Delo 400 and think it's an excellent oil.
You won't find the kind of oil filter you want at Costco.
Get a Fleetguard # LF3894 oil filter. This is also called the Stratapore filter.
Get a Fleetguard # FS19579 fuel filter, too.
Sources..... www.genosgarage.com or Cummins.
Adam,
When you come here on Friday There is a Cummins here not to far off the freeway. Great prices on Oil and Fuel filters.
Mike
I have used Rotella in most all of my diesels and Fleetguard filters, i use Amsoil Synthetic now and a dual bypass in my Ram though.
