That’s not nearly minimally long enough as to drain time.Make no mistake. I CAN do a oil drop on my truck in 20 minutes. In fact, I’m probably the only ASE Master Tech in this discussion.
My post is about how I like to do it, when it’s a hobby, and I want to stay clean.
Proceed as you wish.
My method is the same for almost all vehicles, but I’ve been doing it like this on my Rams since ‘97.
Come home from work, or a short trip (oil is near op temp). Pop the hood, go in the house for a half hour to say hi, etc.come out and drop the oil, inspect and grease the chassis, then drop the filter (most times there won’t be more than a bribble) and button ‘er up.
My theory is that the warm oil will siphon back through the pump/ pick up tube/ filter until there is an air break. At which time, the filter will be about 3/4 full.
I believe this happens when you let it sit overnight, but I’m a big believer in impurities coming out better with warm oil.
Put your 3 jugs in and call it a job. Mine is ALWAYS on the F/E in SAFE. Sure as the tide.
I guarantee you after getting oil changed at the Dealer and they add 12 quarts you WILL be overfull.
You should always pull the fill cap first. But I have to agree with Dasmoeturhead that there has never been a Cummins damaged from running a quart or two over full. Just pull the stick with the engine running and it will more than likely show below the lower safe line. Drain it, fill it with 11 or 12 whichever makes you fill better. Then drive it till next change is due.
I've owned all four generations of Ram Cummins and filled 12 quarts of oil in all of them. Always showed oil on the full mark on the dipsticks. I expect the same when I change my 2017 for the first time. Ron
I take it you’re not doing the oil change service every 6 months if you’re not hitting 500 hours or 15,000 miles in six months?I've owned all four generations of Ram Cummins and filled 12 quarts of oil in all of them. Always showed oil on the full mark on the dipsticks. I expect the same when I change my 2017 for the first time. Ron
Oddly enough......my 1998 RAM 2500 12V and my 1999 and 2000 2500 24V’s only required 11 quarts to get to the full mark. I always remember having a leftover quart from the three gallon purchases.
Hey guys,
My bad on the oil amounts: My former 1993, 2000 and 2002 DID hold 11 quarts with filters. My former 2003, 2009, and my current 2017 holds 12 quarts of oil with filter. You guys got me thinking and I went and looked it up.
I was wrong and admit it. Old age and 41 years working for the government, yeah, that's it.
Cheers, Ron
Back to the over full problem, this same thing happened to me once, I put three jugs of oil in a truck before I realized they were 5qt. jugs. Automatically 3qts over, just an idea you may want to check. We all make errors sometimes.
