A strap filter wrench works well. These use a 1/2 socket drive, you get the web strap around the filter and move it to the top area, just below the flange, and then wind up the strap to turn the filter. Looking down from the top you are going to turn it clockwise to remove it. I remove the turbo inlet hose to change the oil filter.
Use the Fleetguard LF3894 Stratapore oil filter, and next time plan ahead and have a Geno's garage HD drain plug to put back in the pan. Some people prefill the filter with a quart of oil. Do not get any dirt or the little tin seal from the oil bootle in it. Do not over tighten the stock drain plug. You will break the flange off of it. Might want to look at it. If gasket flange is about 1/16 inch thick it is the stock one. Geno's flange is about 3/16's of an inch. Delo 400 15/40 is a good oil. The drain plug is designed to let the oil come out with just loosening it. After most of the oil is out, then remove it and clean it up.
Do not let a FRAM oil filter within a 100 miles of your Cummins. Make sure you have a container that will hold the 10 or 11 quarts of oil that is going to be coming out and that you can get the container out from under the truck when it is full of oil. Seeing as your truck is 2 wheel drive, this could be a real issue. You Might want to drive up on some blocks. Also make sure the truck is warmed up before you drop the oil.
Snoking
