Sterling94803
i have a 94 dodge with the cummins diesel..... when i got it there was 64k miles on it... ... when i would change the oil filter it would always be full of oil and make a mess when i removed it... ... it now has about 145k miles on it..... about 40k miles ago i noticed that the oil filter was only about half full and didnt get oil all over everything when i changed it... ... i also noticed that it now takes a full 4 seconds for the oil pressure light to go and for the oil pressure gauge to show pressure when i start it... ... even if it is only shut off for 15 minutes it takes a full 4 seconds..... the oil pressure is now much lower than it used to be..... i think that might be because of all the "dry starts" while the oil pump is filling the oil filter... ... .
is there a backflow preventer or check valve in the oil system that prevents the oil from draining back to the oil pan? i have checked the pressure relief spring and plunger and they are both as they should be... ... i have looked in the shop manual and the cummins parts catalog and cant find anything in the oiling system that looks like a check valve.....
hope somebody knows something about this... ... thanks
