On my 96 Ram 2500 w/ the Cummins Turbo Diesel, I changed the oil on day , torqued the oil drain bolt to the specified 60 ft. pounds (that seems like alot!), and the oil drain bolt head broke off! The threads were (seemed) o. k, I bought a new oil drain bolt from Cummins, intstalled it (it went on and threaded fine), bough a new torque wrench and tourqued it again to 60 ft. pounds, and everything went fine, but it now leaks very slowly a couple of drops here and there. Why is it still leaking? Is the oil pan messed up? the threads looked fine? The new oil drain bolt came with a brass or copper washer, is that like a gasket? how can I stop the leak? even though it a small, slow leak it worries me... .
Phil:{
Phil:{
