Engine/Transmission (1994 - 1998) Oil drain bolt
On my 96 Ram 2500 w/ the Cummins Turbo Diesel, I changed the oil on day , torqued the oil drain bolt to the specified 60 ft. pounds (that seems like alot!), and the oil drain bolt head broke off! The threads were (seemed) o. k, I bought a new oil drain bolt from Cummins, intstalled it (it went on and threaded fine), bough a new torque wrench and tourqued it again to 60 ft. pounds, and everything went fine, but it now leaks very slowly a couple of drops here and there. Why is it still leaking? Is the oil pan messed up? the threads looked fine? The new oil drain bolt came with a brass or copper washer, is that like a gasket? how can I stop the leak? even though it a small, slow leak it worries me... .
Phil:{
60# is too much. I think they revised it to 44# because of that problem.
I just use a 3/8 drive ratchet and hold it close to the ratchet head. Just tighten til snug. Never have had any problems with it loosening whatsoever.
Thanks for the reply, and advice about only torqueing it ti 44 ft. pounds, but what can I do about the slow drip/leak from the oil drain bolt?:p
Copper probably. They are not good for repeated usage.
I think you have the same pan/plug as me.
I had the same problem and it was a simple cure. I got the laminated rubber/steel washer. Put the rubber side to the pan and snug the bolt as bmoeller stated.
Thanks!
Thanks so much, where can I get the laminated ruber/steel washer for the oil drain bolt? From Cummins? Or from Dodge?
You may have distorted the sealing surface on the pan when it was overtorqued. Some folks have been able to flatten it back out with a sanding block. Of course you will lose your oil, might want to wait till next change time.
Never used a torque wrench on mine, doubt if I'm appling more than 25 ft/lbs, no problem with 57 oil changes behind me with the same plug and washer.
I also had the same problem on my '96, though it occurred while using the specified 44 ft/Lbs of torque.
Illflem is right, the sealing area of the pan distorted and I could not get a good seal even with a new plug and washer.
Another CTD owner gave me the solution - make a washer out of some type of sheet gasket material. I've been using cork for the last 3 years, mainly because it's easy to cut. Just use the factory washer as a template and cut one out. A sharpened piece of 3/4" copper pipe makes an excellent punch for the center hole. Put this washer between the factory washer and the pan. I now torque to 25 ft/Lbs.
I've been doing this for about four years and I have no leakage at all.
Bob
Thanks Bob
Thanks Bob, I believe you guys are right about the pan distorting. I'll make the cork gasket at the next oil change.
PhilOo.
Replacement at Geno's
I bought the replacement from Geno's that has the 9/16 inch bolt head. It comes with what appears to be a hard plastic gasket. I've had no leaks, and I carry the OEM allen wrench plug as a spare.
As an experiment, I torqued the new plug to 40 ft-lb, which is the recommended amount. At the next change, it took about 60+ ft-lb to break it loose. (The wrench pointer was a tad difficult to see anyway, and it went sproing when the bolt let loose. )
