Torque to spec. In your owners Manual. Put anti-seise compound on male thred just enough to do the job . Or do like Me and get the drain Plug replacement ,valve ,cap and hose assy . Ron Bissett In Metro Louisville KYOriginally posted by rrab1
Guy's, Need help asap! went to change my oil today and I rounded(almost broke off):--) the 9/16 hex head. I bought a torque wrench last oil change so I know that it went back on at 40ft/lbs, any help would be appreciated Don
Originally posted by DWeiler
Hello Don , I had the same problem with mine as well. I brought a direct replacement plug from Geno's Garage. It's a 1-1/8 socket drive and has a magnet attached to it as well. Don't know what i paid for it, check genosgarage.com DW![]()
Originally posted by rblomquist
Same here. The advantage of this over a quick drain is all the oil in the pan will come out rather than leaving a 1/2 inch of dirty oil in the pan (area above the lip of quick drain).
Either way is better than stock though.
Originally posted by EricBu12
Get the oil plug that has the lever to open it.
I have had mine on almost since new and it works great every time, not once has it tried to open by itself, it has a spring and a detent to prevent that, The thing is, no unscrewing and getting oil on your hand when you drain it.
