Oil Drain Plug
starter
New oil sample
Talked to my dad tonight. Changed the engine oil in his '95 and the plug gasket tore this time. Got it to seal for now but the Dodge dealer wants $7. 50 for a new seal. Parts stores didn't have any for his application in there books. Can any of you help with a different seal number. Thanks.
I don't know about the gasket you need but I have been using the ez-drain plug from Geno's garage. Works great and you never get spashed with oil. Comes with a clear plastic tube attached which can go right into the pan. Just hand tighten on the tube and its a snap. Look into it . You may like it. ;)
When I needed one I went to my local NAPA, they pulled out a box with at least fifty different sizes, choice of aluminum or copper. I went for copper, it was $1. 25.
drain plug gaskit
I got mine a the hardware store . 75 cents it was an ace hardware store. it was in the drawers mix in with nut and bolts and clearly marked. hope this helps good luck. .
