Oil Drip
  • Thread starter Thread starter NStates
  • Start Date Start Date
Quadzilla Boost fooler
RPMs?
N
NStates
Guest
I have a very small leak that occasionally appears on the floor. The oil appears after I park and is dropping on the sway bar slightly left of the center of the engine. I can not find where it is coming from. Has anyone had the same problem?
ROVOL
2008 Dodge RAM 3500 Laramie Quad Cab 4X2
6. 7 Liter Cummins (R) Turbo Diesel Engine, 6 -Speed Automatic 68RFE Transmission, 3. 73 Anti-Spin Differential, Brilliant White, ISSPRO Gauges, Transfer Flow Fuel Tank, PullRite #20,500 Super 5th Hitch, Line-X, XTRA Bed liner , Hayes Genesis brake controller, PML Deep Transmission Pan, Custom Graphics, Pull a Mobile Suites Fifth Wheel.
Could it not be the crankcase breather tube, which is normal!
Sorry, no breather tube to the atmosphere on a 6. 7.
When you say to the left side of engine, is that looking at it from the front or from the drivers seat? If it is from the front of the truck, check around the oil filter and filter housing.
EB
Also check the power steering pump. If you pull the cap and it seems pressurized you most likely will need to do the mod to the cap. They are supposed to vent, but the don't and build pressure inside the pump. I have seen brand new trucks with 10 miles on them with leaks in the PS Pump.
BTW, my 6. 7 seems to have a bit of an oil leak around where the rear main seal is. I can never really confirm, but seems to be comeing from teh inspection plate on the trans. Anyone else have the same?
My valve cover gasket was just replaced due the back of the motor being wet with oil. Could it be dripping down on yours?
