And that is just what a good marketing campaign would want you to do!
Oil, is oil. One brand of conventional oil to me is the same as another brand of conventional oil, the only difference is the price. Which is greatly influenced by the rate of advertisement. Synthetic oils are a little different, since the new regulations on synthetic vs semi-synthetic oil, there is a difference between oils brands. Not in the oil itself, 100% synthetic oil is 100% synthetic oil and the same. But one has to be very careful now days because oil makers are allowed to sell oil labeled as 100% synthetic, when in fact it can be deluded by 30%. And semi-synthetic oil is anything over 30% . Mobile-1 use to be a very good oil, I used it for years and liked it's performance, but they switched several years ago and started using the deluded oil. Just recently they released a better Mobile-1 which is suppose to be pure synthetic, I can not recall the name but it is there premium oil. The biggest problems are the best known oil brands, Penzoil, Valvoline, Quaker State and so forth. They depend on the brand name to sell the products. In my opinion the best synthetic oils are Red Line and Amsoil, they are the only true 100% synthetic oils I know of. The Mobile-1 premium oil would also be great, as long as they keep it true.
Becarefull here: Oil is not Oil... .
Let's just put the truth back to his statements on Semi-Synthetic.
A base oil can be only one of the five categories occording to the American Petroleum Institute (API).
Group I Viscosity Index < 90 Sulfur < . 03 Saturates < 90
Gorp II VI > 90 < 120 Sulfur < . 03 Saturates > 90
Group III VI >120 Sulfur < . 03 Saturates >90
Group IV PAO (Poly Alpha Olaphin) Synthetic Hydro Carbon Starts its life as dino
Group V All others - for engine oils we use an ester with the PAO
Based on this information you can have a blend of base oils and still be a "true" synthetic. As a matter of fact both of the brands he mentioned use a blend. You see a PAO does not like additives and therefore must have a carrier hence, we use ester Group V to carry the additives and then Solulblize into the PAO. This is at about 15- 20 % for a CI-4+ oil. Finished Lube cost > $20 per gallon.
You can have a full synthetic of the Group III variety. "This is the one he does not like" :-{} . Although it has a higher pour point than PAO it has the high temperature characteristics of a PAO and makes a great engine oil. It carries the additives with little help. The additives are made with Group I as the carrier. 15 -20% additive / cost $12-15 per gallon.
Then you can have a semi-synthetic- this just means you need to wave the
magic wand over the product.
Most will contain 30% of a synthetic Group III or Group IV. With the balance Group I and II. Still makes a great product in a balanced formulation. 15- 20% additive / cost $7- 12 per gallon
And then we have the old stand by, "Dino", as it is refereed here. This is usually today a Group II + and additives to make CI-4+. And this is also a great product used by over 90% of the Class 8 trucks going over 1 million miles!!!!!!! Cost whatever we can get usually around $4- 6
Base Oil School is now out. :-laf
So oil is not just oil when it comes to base oil.
Mobil 1 car oil (PCMO to me) is now a Group III it use to be a PAO. Changed last fall. Not several years ago.
Warren
