Oil/Fuel Filters
sweet exhaust smell
Can Diesel Fuel Additives prevent injectors from failing?
Carl
Thats right same fuel filter.
As far as the oil filter goes, it depends if you want the "Fluted" style which the use of a six in one wrench can be used for removing it from the bottom. Or the standard if you want to remove it using a strap wrench or similar from the top. I use Fleetguard filters.
*Fuel Filter FS-19579
*Oil Filter (non fluted for removing from top) LF-3894
Mac
