My truck---> '96 12v, 5sp, 4x4, w/lousy factory oil pressure gauge. Took it to Cummins SW in Albuquerque where they put a mechanical gauge on it. At idle: factory gauge-36 lb, mechanical test gauge (accurate to +/- 1 lb. ) - 58 lbs. They said it's probably a bad sender. Drives me nuts... after the oil is hot, the stock pressure gauge is all over the place - flicks back and forth between 0 and 45 depending where your right foot is. Anyway, I would like to run a mechanical oil pressure gauge out of the port on top of the oil filter housing (the one next to the turbo oil feed line).
Does anybody know the thread size of the plug in the top of the oil filter housing? It would be nice to know what size fitting to get before I go shopping.
Also, where's the best place to hook up the gauge light so the brightness is controlled by the dash light dimmer on a '96?
TIA/Cheers
Tom
TIA/Cheers
Tom
