Archived oil leak behind computer
Archived 96 won't start
Archived Body shop warning!! 2nd Gen' trucks & newer
my 2007 6. 7L has an oil leak behind computer mount plate
loosened computer and mount plate
when we moved the plate a steel "thimble" fell out from behind it
there is a hole that may be for a different dipstick location
we think the plug fell out from there
we put the thimble back in but it went in too easy
so we put red loctite on it and siliconed it too
i'm wondering if i may have a ventilation problem
with the crankcase i'm not sure where the vent is
does anyone have any ideas
thanks
i let the loctite and silicone harden up for a couple hours
and then took ir for a drive so far its not leaking
but i dont really know what caused that thimble to come out
could it be too much pressure in the crankcase or did it
just work its way loose
thanks
mine did that last year when coming back from camping the dealer said its just a plug in block for different locations for dip stick
thanks jam but did the dealer say what may have caused it?
maybe rattled loose or crankcase ventilation problem?
any info greatly appreciated!
If it was a plastic plug, then it should have been replaced with a steel plug. Kind of like a freeze plug. Had the same thing happen on an engine replacement in a bus that I did. Didn't even see the darn thing. The bus made it 1 mile down the road before it popped out.
