the other day I put a quart of oil in the truck that I don't normally use, didn't want to but it was all that I had in the garage and was in a hurry.
The truck has leaked a little bit of oil since the day that I got it, which also pisses me off.
Anyways, I ran about 35-40 miles down the freeway (65-75mph)
Well, I stopped and was in a resturaunt for our club meeting and I came out and there was a puddle about 8 inches in diameter of oil under the truck. The tailgate was covered, oil was dripping off the rear axle and the whole underside of the truck is now rust-proof.
What the heck did I do?
I got home, changed the oil, and pressure washed/degreased the motor/underbody/axle. This is REALLY starting to bum me out.
I pulled the inspection cover, dry (which is a plus I spose) meaning that I dont have a rear main leak. I thought maybe I damage something internally causing massive quanities of blow-boy, as it looks like some oil MAY be coming from the vent tube.
Part of me doesn't think its the vent tube as the passanger side of the motor also is leaking oil. It runs down and drips off the bottom of the trans inspection cover.
I looked with a mirror and it doesn't appear to be leaking down the side of the head or the back of the head indicating that the vavle covers are not sealin, but part of me still thinks that it could be the culprit as it's the 3rd set I have put on it in 2 months.
The other part of me thinks that replacing the valve cover gaskets was chasing a different problem.
The motor is covered in oil, (front cover is leaking as well, plan on fixing that this weekend when I tab the KDP) I can NOT tell where this is coming from. Leaks down both sides of the motor... I'm ready to pull out my hair...
PLEASE anyone. . advice is greatly appreciated. The leak in the front doesnt bother me nearly as much as the leak in the back as that would only leave a drop every few days, the leak in the back is leaving a puddle now... .
Theres no water in the oil or oil in the water.
Anyways, I'll stop now.
