oil leak
Removing cat on 2007 5.9
heater block?
I have an 04 2500 and I found a light brown colored oil leak that looked as if it was coming from the a/c compressor. Does the compressor have oil in it or could it be coming from somewhere else?
Thanks alot
More than likely this is coming from your oil filter. The oil filter is directly above the rear of the A/C compressor.
My compressor has a little drop of oil on it almost every time I change the oil. It comes from oil dripping down from the filter when it's removed for changing.
Check the oil filter to be sure it's not leaking.
Ryan
Thanks,
After doing a little more investigating, it is anti freeze, My truck has red anti freeze. I still can't tell were it is coming from though. Maybe my waterpump is going bad.
