1996 2500 Ext Cab Longbed 12v 5. 9L Cummins
I have an oil leak coming from the adapter between the vacuum pump and the power steering pump. It looks like it is leaking through the seal in the adapter with the spring in it. i've taken it apart, reseated the spring into the seal and put it all back together. I thought it was fixed b/c it didn't start leaking right away like before, but it appears it has started leaking again.
Has anyone else experienced this or fixed it. I'm pretty much new to the diesel life, so any help would be very much appreciated.
Thank You in advance.
