I'd make my judgement based upon the severity of the leak. Is it leaving a puddle overnight? It probably should be fixed. A few drips? I think it's going to drip a little until it gives me reason to spend a lot of time trying to keep a pint or so from leaking from the engine between changes. It's simple economics. And how "severe" a leak is and how much a problem it may be are all completely subjective. I've fixed "leaks" that were nothing but a little dust attracted to the tiny amount of oil that invariably makes it through a paper gasket and have NOT fixed "leaks" that were almost steady streams that would empty the system in hours. It's all subjective and all up to the person writing the check. I don't LIKE oil leaks but then again I don't expect an old engine design that doesn't have all the sealing technology we do today to stay "perfectly" clean and dry, either. Inevitably front main seals leak, rear main seals leak etc and at some point there will probably be a repair required that necessitates major work to do it. Such as pulling the engine. I'd monitor the leak, wait until it either gets REALLY bad (once again that's subjective) OR until other leaks occur and it reaches a point where I can kill many birds with one stone and just pull the engine and reseal it.
That's how I look at it. I never split a tractor without putting a rear main seal. I never replace a crankshaft damper without putting in a front main seal. But yet I've seen guys that have done both. At the same time, I've seen guys try to do multiple in-frame engine repairs or modifications either simultaneously or close enough together that they could have been, and yet do twice as much work to avoid the work of removing the engine than it would take to remove the engine and do the job. I'm NOT saying the engine has to be removed. I'm just saying that I would look at that leaking tappet cover gasket and wonder about the condition of OTHER MOVING seals and just how much sense it makes economically to do those INEVITABLE repairs separately vs. simultaneously. Big-picture thinking, I guess. Of course some will say or think that I'm a mechanic and I just spend other peoples money. Yes, I do. But I also usually have to explain how and why I'm spending their money. And when it's a job that I REALLY don't care for and don't make money at but I recommend it anyway, it's not my best interests I have in mind with my "let's bite the bullet and fix existing problems and IMPENDING problems simultaneously" approach.
My '02 has HVAC problems. The temp goes from ice cold to too hot in one notch, theres a fan problem or something blowing around in the ducts causing a buzzing noise and I'm pretty sure there might be more problems that that I don't know about or that will show up. And my dash cover is also cracked. Doing a little YouTube research I've found dozens of "repairs" for broken dashes and HVAC problems that all promise to be "easy'. The only problem is that NONE of the "easy" ones are the FACTORY methods for restoring FACTORY performance or appearance. Invariably, they are ALL shadetree "workarounds" and not repairs at all. And they all claim to be cheaper or quicker than what the "dealership" would charge. Well, I'm guessing that's probably right. Is the dealership going to do a FACTORY-SPECIFIED REPAIR for shadetree costs and non-factory performance? Not so much. One guy was whining about the dealership him quoting him $2300 to fix the A/C system. I'm guessing they don't DICK with removing the original HVAC module, putting in a few new pieces and throwing it back together so in 5000 miles the heater core or some actuator or fam motor can fail while it's still under repair warranyt. They probably replace the whole thing and call it good. I'm not going to go THAT far but I AM going to look closely at the heater core and will probably replace it. And I'll probably vacuum test the A/C system BEFORE I disassemble the truck and look at the evaporator closely too. And I'm going to go to "all that work" to pull the dash and everything because I have multiple existing and maybe impended HVAC problems AND the A/C is low on refrigerant AND I wasn't to flush the cooling system AND I want to fix the dash correctly.
