On the second to last oil change I installed an EZ drain plug from Geno's. The next time I changed the oil, I noticed that I couldn't add as much oil as before, about a quart less. I suspected that the EZ plug stuck up above the bottom of the pan, keeping all of the oil from draining. My plan was to remove the plug next time, measure the thickness of the pan and make a spacer so that the top of the plug was flush with the bottom of the pan.
Today I changed the oil again and removed the EZ plug after draining as much oil as I could using the drain tube. When I did remove the plug, I noticed that the remaing oil came out in 4 separate streams. When I check into the cause, I found that the threaded insert in the bottom of the pan is cross drilled close to the bottom.
I don't know if anyone else has discovered this, but it means that a different approach must be taken to design a quick drain plug that will drain the pan completely.
I put the stock plug back in and I guess I'll get a Super Plug to keep in reserve.
