Details here: TDR Privileges
I can answer this one to a "T"... ... ... ... ... ... . just had mine done at the srewballs... ... ... . um, I mean dealers. The book gives 7 hours. Here is what they did:
-removed the trans, transfer case, etc. and flex plate.
- had to ift the passenger side of the engine 7" for the pan to clear the crossmember.
-installed gasket and sealant per TSB 09-006-01 .
-Put everything back together... ... ... well almost
and gave my truck back.
All in all, a very big job.
If you go to the dealers, double-check EVERY connection on your truck. They left one of mine dis-connected.
