oil pan gasket
New lower control arms, shocks and leveling kit
axle seal leakage
ALE8-1
What is involved in changing the oil pan gasket?
Any suggestions. :(If its not to hard I will do it
myself. I hate having the stealer do it. 4x4 2000
29,000 miles its been like this since about 4500miles.
Thanks for the help.
ALE8-1
I can answer this one to a "T"... ... ... ... ... ... . just had mine done at the srewballs... ... ... . um, I mean dealers. The book gives 7 hours. Here is what they did:
-removed the trans, transfer case, etc. and flex plate.
- had to ift the passenger side of the engine 7" for the pan to clear the crossmember.
-installed gasket and sealant per TSB 09-006-01 .
-Put everything back together... ... ... well almost:rolleyes:
and gave my truck back.
All in all, a very big job.
If you go to the dealers, double-check EVERY connection on your truck. They left one of mine dis-connected.
HTH
George
Hmmmmmmmmmmmm, remember... ... ... ... ... . COMPLETELY STOCK!!!!:D
Anywho... ... ..... the gasket wasn't affected by any of the mods, therefore... ... ... ... ...
HTH
