Engine/Transmission (1994 - 1998) Oil Pan size???
Engine/Transmission (1994 - 1998) pyro
Hey All. I am in the process of dropping a cummins into my GMC. The 1996 12valve I got had the pan dinged up quite a bit so I have a new one on the way. My question is that I also have a 5. 9 that came out of a hi-ab crane. It is rated at 126HP @ 2600 rpm. This engine actually thru a rod out the side of the block. I got it for free and wanted it as a mock up motor for my conversion. Anyway, it has a brand new oil pan on it that is quite a bit larger than the 5. 9 truck pan. I would have to say that oil capacity is half if not double of what the truck pan is. I have this big pan on the mock up motor and its sitting in the truck and clears the crossmember just nicely.
Do you think I am better to put the larger pan on the engine or should I go with the truck pan. How many quarts does the truck pan hold? if I went with the larger capacity pan could my oil change intervals be extended??? My way of thinking is that the more oil capacity the better but I just want to know what you all think!
Thanks... Ryan
More oil gets you better cooling capacity but I wouldn't expect it to increase change intervals. The truck motors as set up require 11 quarts, most guys use 12. This is plenty of oil for a pickup IMO.
-Scott
If I was using the peacup 24/7 pulling trailers or working it hard then I might consider a bigger pan but I have to agree with SRadke that 11-12 quarts seems to do the job. Another thing is the cost of that additional oil and changing time.
Go for it!
I'd go with the bigger pan in a heartbeat as long it doesn't present any installation or driving problems.
You certainly wouldn't need it though--the stock pan is perfectly adequate. It all boils down to what you want to do.
Mike
I'd use the smaller pan... even if the big one fits.
The smaller pan might make it easier for you to work on stuff down there in the future.
The 11/12 quart pans have plenty of capacity to make the bigger pans unnecessary in pickup trucks...
Matt
I'm using a front sump pan with a capacity of 15. 3 quarts plus filter equals total of 16. 3 quarts, whichever you choose make sure you use the right pickup tube.
