Hey All. I am in the process of dropping a cummins into my GMC. The 1996 12valve I got had the pan dinged up quite a bit so I have a new one on the way. My question is that I also have a 5. 9 that came out of a hi-ab crane. It is rated at 126HP @ 2600 rpm. This engine actually thru a rod out the side of the block. I got it for free and wanted it as a mock up motor for my conversion. Anyway, it has a brand new oil pan on it that is quite a bit larger than the 5. 9 truck pan. I would have to say that oil capacity is half if not double of what the truck pan is. I have this big pan on the mock up motor and its sitting in the truck and clears the crossmember just nicely.
Do you think I am better to put the larger pan on the engine or should I go with the truck pan. How many quarts does the truck pan hold? if I went with the larger capacity pan could my oil change intervals be extended??? My way of thinking is that the more oil capacity the better but I just want to know what you all think!
Thanks... Ryan
Thanks... Ryan
