Engine/Transmission (1994 - 1998) Oil port for bypass return?
Engine/Transmission (1994 - 1998) Power Loss?
Is there an oil port somewhere on the block where I can return oil from a bypass filter? I don't want to hole my oil pan.
Thanks,
-john
Johnstra said:
Will those filler caps from oilguard work on a 12-valve? If so, I'll get one.
-johh
Not sure John. Give them a call and check it out. When I bought my system they supplied one that replaced the oil drain plug where the return went. The other side of the plug has an allen screw that you remove to drain the oil from the pan. You could ask about that one also as I did not see it on the website.
Dave
