My 98 12v recently started giving me a zero oil pressure reading and "Check Guages" alarm at idle speed (750 rpm). This would happen only after the engine was fully warmed up. Initially it would occur only after running on the highway and most often when towing. The condition could be corrected by bumping the rpm up a couple hundred. I put a guage on the oil filter housing plug and found the oil pressure was not going to zero. So, I replaced the oil pressure sending unit. Fixed... or so I thought. Worked for 2 weeks and is doing it again. Oil pressures: 65 psig at 1500 and above (hot) and 25psig at idle (hot). These numbers are from the mechanical guage run at the oil filter housing. Seems to be doing it more often now. Running Stratapore filter with Rotella T and Power Up additive. Truck has 130,000 miles on it. Any ideas? Thanks.
