When the engine is warm, like after towing for a couple of hours and I go to start off from a dead stop, the rpms drop a bit and then I'll hear the dinging. I look at the oil pressure and it's either bottoming out or close to it. This only happens when when the engines been loaded for awhile and ther is that rpm dip from take off. There is no rod knock like from loose bearings ever. I'm thinking sending unit or is there a relief valve to maintain pressure somewhere that might be failing. Engine has about 85k.
Thanks,
David
Thanks,
David
