In my 98, 24-valve Dodge, the oil pressure gauge always stayed steady at a high-normal reading, regardless of RPMs or temperature. This seems to be true for many other 2nd generation Cummins owners that I’ve talked to.
On my new 03, 305 HO, however, the oil pressure gauge fluctuates between low normal and high normal, depending on temperature and RPMs.
QUESTION: Are other 03 owners noticing the same thing &/or is this something that I should be worrying about?
P. S. I did change out the original Mopar oil it came with after 6000 miles of mostly heavy pulling, but the new Valvoline Blue 2000 is acting much the same (although it doesn’t go as low as it used to, it does go a little higher).
