I have a never used oil pressure gauge . Can it also be used as a fuel pressure gauge? I have a tapped banjo bolt at the exit from the fuel filter. If the oil pressure gauge will work does it just have to be hooked into the fitting at the banjo bolt or am I missing something?
The scale is 0 to 100 lbs but the lower pressures are pretty clear.
Thanks any info.
Thanks any info.
