nickleinonen said:which ever is easier to get access too... you can also get pressure from the lube oil gallery in the block. the left side of engine, there are 2 accessable m10x1. 0 orb ports [one below/behind cp3, one above ecm]. reads a little lower than the filter head. . [and leaves the filter head open for a lube oil temp sensor]
is there any reason why you couldn't use on of the filter ports for an oil temp and the other for an oil pressure?
he ports on the left side of the block, do they have what looks like a hex or allen wrench look to them???
DaveHess said:When you pull one of the M10x1. 0 with the truck not running, will oil spill from the hole? I am guessing that with the truck running, oil flows past these ports and therefore would be better for oil temp. Where as the port at the top of the oil filter would be better for oil pressure considering the flow is somewhat limited. Any other thoughts or considerations? Thanks Nickelinonen for your help!
There is only one and sometimes 2 cam bearing (bushings) in the 3rd gen engine.
