Initial posted this in the 911 section. Looks like less of an emergency as I investigate more. Problem started first time today, 199K miles on my 2000 auto. Oil pressure gauge dropped to 0, check gauges light came on and I heard a "ding". Happened again about 4 times on the way home when engine dropped back to idle in gear. Came home, changed the oil and filter and started truck. Oil pressure seemed OK now (about 60 cold). Drove the truck about 40 miles and observed the following. Oil pressure steadily drops below 40 and will not read above 40 again until another cold start regardless of engine speed. I stopped by the dealer, the mechanic let me install the test gauge after he burned his fingers a few times. I installed it on top of the oil filter housing at the 1/8 inch npt fitting. Dash reads about 20 psi when the Snap-On mechanical gauge says 21 at idle in gear. When I rev the engine, pressure goes to 40-70+ almost instantly on the test gauge and only gets to about 39ish on the dash gauge. When the gauge slowly drops down to about 21 indicated, it suddenly drops to 0 like I turned the key off , lights the check gauges and dings. This happens almost every time I let off the gas and the engine returns to idle speed (in gear) when the motor/oil is hot (190+). When in neutral, does not happen (engine speed and oil pressure slightly higher). I have guessed that the factory ECM program for the oil pressure gauge drops to 0 when it sees 20 or less psi? I have a virgin 2000 auto ECM. Dealer suggested a new pressure sender at $200 for the part. Going to call Cummins parts counter tomorrow and check price. Anyone an expert on this subject or had a similar experience?
FYI, oil pump is about $192 @ Cummins (Cummins PN 393 7404 at least for my engine SN) and almost FOUR hundred at the DC parts counter. . Parts guy said he doubts an oil pump as do I.
