you got yourself a glorified hobbs switch. . 6psi it shows pressure, less than that it shows none. .
the switch is on the left side of the engine, behind the ecm on the engine block. the green colored connector below the fuel filter canister in the picture below is where the switch is.
check your oil for fuel contamination. . hot idling is when fuel dilution will drop pressures low enough to trip the switch
price for the switch is in the $30 range i believe
