If you had the engine apart and cleaned, the oil galley plugs should have been removed. There is no way to get all that metal out without removing them. If they weren't, all this will go through the new bearings and could possibly plug a piston cooler jet. Always replace the oil pickup after a mess such as this. Don't know about a gasket on the pump but there is one on the pickup. I have one in the shop partially torn apart, I will remove the pump tomorrow and see if it has a gasket. Think I would check with the machine shop about the plugs, too.
