R-N-R:
There are several places to send oil samples. As I said, I use
BlackStone Labs There is also Oil Analyziers, Inc. which I believe is through Amsoil and several others.
Right now, Blackstone is charging either $17 or $18 per sample. I think Oil Analyzers is close to the same.
Blackstone sends you the results of your current sample, averages for your type of engine that they have analyzed in the past, and the 4 or 5 most recent samples from your engine so you can look for any trends in each wear metal/particle. Oil Analyzers also send you what is called a TBN (Total Base Number) in their report. Blackstone will also, but they charge an extra $10 for that. The TBN number, as several oil gurus here have said before, is supposedly the most important number on an analysis report for telling you how much useful life a given oil sample has left in it. Meaning, how much longer can you use that oil before it must be changed.
When you send in your sample, you fill out a small form that tells the company several things: what type engine, type and weight of oil, miles on the engine, miles on that oil sample, etc. . That way they can make informed recommendations as to the ability of that oil to go for longer change intervals the next time.
It usually takes about 2 weeks for Blackstone to send me my results. Although they recently began offering the report in email as well as printed copy, and I get the email usually in about a week.
If anyone is interested, I would be more than happy to email you my latest Blackstone report, which I got last week. It is a PDF format, so you would need Adobe Acrobat reader to view it. Send me a PM or direct email - see my signature for email link.
Tom
