Oil seperator question
2 micron fuel filter and smarty jr
quazilla rail/fuel pressure guage problem?
Is there an o-ring that seals this thing to the valve cover, mine seems to be leaking for some reason. would like to know before I pull it apart again.
I dont know about the o-ring but it's fairly common for the 03 to leak from the hoses that attach to the breather under that plastic cover. If it is, a couple of hose clamps will fix it.
Scotty
Have the big hose zip tied to the seperator, just wondering if there is a o ring that seals the unit to the valve cover.
yes, there is an o-ring seal. Remove the two hold down screws (8mm or 5/16" head) and the black plastic filter unit can be pulled up out of the aluminum valve cover.
Any one recall what the part number is for this O -ring? Have someone needing one, but can't find my old reciept. #@$%!
