mwilson
The temp should be close on the two, but with our small sump the oil temp has the potential to clime 25-50° above the coolant in a long hard pull. I have heard from from those who measure it that it doesn't go much above that.
As far as emissions, the emissions stuff doesn't care about oil temp or pressure so it really doesn't need to know
The last one I looked up didn't have one.
Yes, the small sump may influence that. A rear gear train 6.7 Cummins in a Freightliner M2 holds around 20 quarts instead of 12.
I was amazed after driving my first big rig with an oil temp gauge. I had always thought oil temps would be high similar to an automatic transmission but day after day the coolant and oil temps would run about the same. They would climb together going up a grade and then drop together when the all or nothing Horton fan clutch kicked in.
Transmissions and driving axles are a different story however.....
