Ok guys, we REALLY need some help here. My brothers '92' (he is a TDR member, just doesn't do 'puters' well)
Is now on his 9th, yup 9th, PS pump.
So far he has put in 7 brand new
which leaked withing 3 days to 4 weeks, put in 1 re-built, same result, and one more brand new one INCLUDING a brand new vacuum pump, just in case it was the cause even though testing said IT was ok.
Now this last time DC who has done all the work said come back so we can give you all your money back, including another new pump which should carry you for another week
He is DESPERATE here guys !!!!
Calls to DC service H. O. , have yielded no new ideas.
The re-built broke the chain of new pumps and the possibility of a bad batch.
It leaks from all sorts of places. One time it leaks from the front end were it joins the vacuum pump, another time it leaks from around the resivoir, other times it leaks all over the place.
Its been put on the pressure tester/simulator repeatedly to check high press. side/low pressure side,,, the works.
I know there are some rocket scientists in the group. . ANY ideas are welcome at this point.
Thanks on behalf of myself and my brother 'Woodie'.
