Archived Ok so it isn't dead... yet! Advice?
Archived Need Help Fuel Leak
Archived Need Help Fast
My 05 started this am and I went about a mile and slowed for a turn, about 20mph and it died! I put it in neutral and started it, started fine, next turn same thing again at every low speed turn. I drove 45miles to work and on the way called the dealership to see if they could look at it. Left it for the day and when I went back they had scanned and no codes and ran fine! Left for home and after about a mile started acting up again. Played with it on the way home trying to get more symptoms or at least a code. At low speeds the tac begins to fall off and then drops around 1000, if I use the throttle to catch it the rpms go down or hesitates before recovering. When it dies I can restart it on the move, still no code. Seems to run ok at highway speeds, maybe a bit sluggish.
I don't have a filter but will tomorrow. Drained some fuel and it didn't look to bad, changed the filter about 2K ago. I have 93K on the clock and bone stock.
Suggestions?
Yes I also believe it to be fuel related but where? My other work truck is a 98. 5 and I went thru the usual problems with the LP and IP but the system on the 05 is totally different.
