Engine/Transmission (1998.5 - 2002) OK so what block do I have?????
Engine/Transmission (1998.5 - 2002) Which Injectors Do I Need??
2nd Gen Non-Engine/Transmission Great mechanic
I looked under my truck all I see is a bunch of numbers and letters but no 50 whatever no 53 no 56. Am I looking in the right spot? I see like 2B then 123(about half ground off) then 00E2A something or another? help? Ive got paranoia like RADDodge was talkin about. I figure my luck the ol' 02' will be the only one with the 53 block! :mad:
From what I've read in earlier posts, it sounds like you've got the Taco (Mexican) Block. Supposedly (sp) the stongest one out there. :D Sixpack
You're not the only one seeing a lot of letters and numbers but it is a good thing. I immediately checked my '99 that is missing at idle if you saw my post to see if I had a 53 also that could somehow be causing it to miss. I have a lot of letters and numbers and this means it is a Mexican block which is a good thing. Anyone have any other ideas on my miss ay idle I need help still. Thanks and just remember Mexican's are good. ;)
