I won't post this in the 911 forum because it is not an emergency (as of yet), but...
Has ANYONE seen or have info on PCU code 0071? Thats right... code 0071.
I saw my check engine light light up on the way home. Before I shutdown, I hooked up the Cummins QuickCheck. It only said code 1693 (companion module coded) which meant the code was in the PCU, not the ECU.
I then dug into my service manuals... no code 0071. I double checked that the key on/off/on was still showing PCU 0071... Yep. I hooked up my computer and thru the Pepper OBD2 software, was able to look at the freeze frame, etc. I still could NOT find 0071. All OBD2 showed was that the MIL light should NOT be commanded on.
So I reset all codes, and lo and behold, the MIL extinguishes. Looked on the web, and I don't think code 0071 exists, but I figured I'd ask here. All appears normal. Any ideas? This one's got me scratching my head.
