Nice pull Scott. You do need another set of tires though, those swampers dont work very good on the tight tracks. They might work better if you take another inch of the tread off though. Good Job !
Turbo Thom said:Scott... ... ... . On the air, I think if you have the head O-ringed and the studs clamped to 150 lbs, that will hold more than you would ever believe, that is with about . 012 protrusion. But then I'm one of those that believes why make more boost that you can use. Make 120 lbs, but show me you will ever use it. Such as why add more fuel and let most of it most of it drip out the tail pipe?
OK, enough of that.
C' Y'all
. . Preston. .
Nate said:All that smoke... it's a good thing? I thought it was basically unburnt fuel??
Sled Puller said:It also has been the ONLY part on my truck that hasn't been giving me fits this year.
BigBadDodge said:Josh, dude sorry about your luck with the head man, hope you get this time huh.
BBD
