Seems I have a strange addiction to truck modifications and additions.. one thing leads to another, or several other things. So I wanted to add rear air springs and level the front with a 2" lift, but that would mean with load the rear would be lower than front, so the air springs were the fix to that. Not being content with just using an external air source, I put together my own on-board air system. The tank is a 6 gallon Al tank, and I'll be running 200PSI at the tank, regulated down to about 120PSI on distribution (adjustable), I added a quick connect for an air hose as well. The air compressor is a continuous duty 200 PSI, and the pressure switch is 165-200. I used a 60A relay mounted near the battery with a control switch in cab, along with compressor run indicator light. I have mechanical gauges on the tank and regulator, with in cab digital indication for the tank pressure, and regulated distribution pressure, as well as indication for each air spring. Also in cab is pressure adjust valves to increase, or decrease air spring pressure, and since I was going nuts with running wires and air hoses I added a switch to select or de-select the air horn, which is activated with the steering wheel horn via a relay. I have some piping still left to do, but I'll put up some of the early pictures and add more as I complete the rest of this system.
